Selecting parameters for ex pedal on H9
Home Forums Products Stompboxes Selecting parameters for ex pedal on H9
    • #114466
      Kristian Kvalvaag
        Hello! I cant’t figure out how to select parameters for the exp pedal to control in the H9 app. Two examples: on the Spring algorithm I want the Exp pedal controll the tremolo intensty and on the Hall algorithm I would love to controll the decay. I am using a Mission standard exp pedal. Thanks!
      • #147667
        gkellum
          Here's a tutorial video that shows how to add a parameter to the expression pedal mapping in H9 Control:
          To remove a parameter from the expression pedal mapping, you double click on it in H9 Control and if it's mapped to the expression pedal, an option appears in a popover to remove it.
          You can do this directly on the H9 itself as well.  The H9 user manual explains in detail how.
