SOLVED [RCV CTL] ? There are new choices for Receive Control
Home Forums Products Stompboxes SOLVED [RCV CTL] ? There are new choices for Receive Control
Viewing 0 reply threads
    • #106605
      All,
      Following on from my previous post – I had "bypass" assigned to the same MIDI controller. Once I switched this to a null value, and then changed the ACT via learn CC it now works ! This is cool as it allows use in MIDI rack setup without the need for a dedicated switcher, thanks
      Hello all,
      Having some trouble setting the following fuction up with the latest beta for TF & MF:
      [RCV CTL] – There are new choices for Receive Control to alter the unit’s
      BYPASS setting:
      ACT – Make the unit ACTive, i.e. not bypassed.
      TOG – TOGgle the between bypass and active.
      Am I right in presuming this function allows changing the switch sense so MIDI controllers (in my case the Ground Control Pro) will switch the bypass (via MIDI) correctly on the TF / MF – i.e bypass on the Ground Control is in "sync" with the TF / MF? If so I cant seem to set this up correctly. What should the ACT & TOG  be set to ?
      thanks in advance.
