Space factory presets in V4
Home › Forums › Products › Stompboxes › Space factory presets in V4
    • #109558
      davidkaeser
        since I updated to V4 with space pedal, some patches don't work as it should work. For example, the dogstar patch works perfectly in 3.2 but no fx in V4 ?
        Is it normal ?
        Thanks 😉
        DAVID
      • #124251
        tritone
          try lowering the fxmix knob.
          before the 4.0 update, the feedback parameter was maxed at "Infinite".With ver 4, Freeze was added for the max value which blocks the direct sound.So lower this knob to inf and save the preset to get the sound as it was before update.
          This is true with Dogstar and also Centaurus (Blackhole alg too).
        • #124252
          davidkaeser
            Oh ! Thanks you very much for this 😉
            Cheers
