Space goes off and on by itself
Home › Forums › Products › Stompboxes › Space goes off and on by itself
    • #111025
      goinz
        Hello, I have a problem with my space it reboots several time a day by it self. I use the eventide power supply and tried different voltage connections in my house and it happens everywhere. I also tried to use my pitch factor power supply but it happens again and again, pitch factor is on the same voltage connection and has no problem. The Space goes off and on again by ghost hand.
      • #124661
        achaput
          Hi Goinz,
          Have you ever come home to find your furniture in a different spot than you left it?
          You have some paranormal activity happening.
          Or, your Space pedal could be a loose power supply jack…
          You should send an email to support@eventide.com with your serial number and username and describe the situation.
