Space: Hot Switch and expression pedal together?
Home › Forums › Products › Stompboxes › Space: Hot Switch and expression pedal together?
Viewing 3 reply threads
    • #108954
      coirbidh_99
        I'm considering purchasing a space to pair with my TimeFactor for ambient looping goodness, and was wondering: is it possible to set different parameters to be controlled by the Hot Switch and an expression pedal in the same patch?  Could I, for example, program the Hot Switch to alternate between a preset decay level and the FREEZE mode, and set up the expression pedal to control Size or some other parameter(s)?
      • #123657
          The hot switch and the expression pedal are unrelated, so they can operate independently.  But, they both in effect control knob-type settings, so will not drive the FREEZE feature.
        • #123658
            Ignore the second sentence – they can both drive the FREEZE.
          • #134699
            coirbidh_99
              I thought that was probably the case, but it's good to be sure.  Thanks!
