Space-Modfactor-Timefactor line/level settings??
Home Forums Products Stompboxes Space-Modfactor-Timefactor line/level settings??
    • #108158
      landonbailey
        I'm using the TF, MF, and Space as the last 3 pedals in my pedal chain. No racks unit, no amp fx loop, just stereo outs to my amp.
        What would be the default setting for the ins and outs? I just assumed it they would all be line in/line outs, with the output set to AMP on the Space.
        But is the line level switch only supposed to be used when run in an fx loop or mixer?
        I've been getting a little bit of noise, and I wonder if getting these right will help.
      • #122765
        achaput
          If they are in front of your amp I would set all the Eventides to Guitar in/Amp out Levels. There is no rule here though, just a guideline. You can set them to Line level Output if you want a little more gain before your signal hits the amp.
          Alan
