Stereo in, mono out?
Home Forums Products Stompboxes Stereo in, mono out?
    • #108298
      What would happen if I plugged in both inputs, but only used the mono output of my space pedal?
      Would it sum the stereo signal it received to mono, or would it still try to out put in stereo, even though the right output was unplugged?
    • #123023
      wedelich
        All the algorithms were designed to take this situation into account.  I don't remember the exact nature of each, but most process the inputs as stereo and either sum the wet outputs (the dry signal is summed to mono).  There may be a  one or two instances where this isn't exactly true, but we made the most musical decsions in those cases.  I can dig deeper if you want more specifics, but for now just know that we planned for this situation.
        The only thing that's undefined is using input 2 and not the appropriate mono input 1.
