Stereo Input to 2 Sets of Stereo Outputs
Home Forums Products Stompboxes Stereo Input to 2 Sets of Stereo Outputs
Viewing 0 reply threads
    • #195128
      JZ092026
        Hello Eventide,
        I am running a line level signal out of the effects sends L & R of my Red Seven Amp Central Evo to 3 effects pedals.
        The original signal is from my amplifier into the Red Seven (not my guitar).
        I want to run my Boss SDE3000EVH delay pedal L and R outputs in stereo into my Big Sky reverb, then out of my Big Sky in stereo L & R into the H90 in stereo inputs 1 and 2, then out of the H90 in Stereo Set 1 L and R: stereo into my RedSeven Amp Central Evo effects returns L and R (sent to my computer converter), as well as, Stereo Set 2 L and R: in stereo into a power amp channels 1 and 2 to run 2 sets of 4×12 guitar speaker cabinets that will have stereo effects in the performance room.
        Is this possible?
        Should I run the H90 (as well as the Boss and Strymon pedals) at line level rather than instrument level?
        Should I use Insert Mode or Dual Mode on the H90 to achieve 2 sets of stereo outputs 1, 2 and 3, 4 on the H90?
        Will any latency be caused by the H90 and/or be audible with either option above?
        If I want no latency, whatsoever, can you recommend a stereo input to 2 sets of stereo ouputs active box that I could plug the stereo outputs L & R of the H90 into, in order to route those outputs to: 1) my Red Seven effects returns L and R and 2) my power amplifier channels 1 and 2?
        Thank you in advance!!!
