Stereo Midi Switch
Home Forums Products Stompboxes Stereo Midi Switch
    • #106409
      To save ports on my roctron patchmate, I was thinking about  putting TF,PF, MF in-line using two inputs (stereo). when sending PC's I would always include the bypass codes on the boxes I wasnt using. Anyone see a problem with each not having its own set of I/O?
      TIA
      NJ-Nick
    • #118997
      caveman
        I think that would be better than using an external switcher. less cabling, fewer things to program, fewer things to go wrong. If it were me, I would probably set the first one to DSP bypass and the others to relay bypass to avoid going through 3 AD/DA conversions when they are not being used.
      • #119001
        Thanks for the advice…makes sense
