Stereo out to TRS input possible?
Home Forums Products Stompboxes Stereo out to TRS input possible?
Viewing 4 reply threads
    • #113535
      Hi!
      I have a concern and need to be sure it’s feasible :
      I have a timefactor and use stereo outputs. Is it possible and safe to use a double TS cable from left and right output merged to TRS?
      I have a device that accept stereo but only using a TRS input
      Thanks a lot for your answers / advices
      Cheers!
    • #143679
        It should be OK, as long as you connect one output to T and the other to R (meaning – don't short them together).
      • #143681
        What do you mean by short?
        the left timefactor output will be connected to T, the right timefactor output will be connected to R  and the other end of the cable (TRS) will be connected to the stereo TRS input of another device. Does this seem good? i see no short here except the common ground (i was mainly concerned about that beceause T and R are not connected together)
      • #143700
          I meant "short circuit." It's OK to tie the grounds together.
        • #143702
          Ok, i was pretty sure but needed to be 100% 😉 Thanks a lot NickRose i’ll test that
