Home › Forums › Products › Stompboxes › Strange Aux switch behaviour with Space work-around fix
June 15, 2014 at 4:50 pm #111709
I have a Space pedal recently updated to v5.00. I have a digitech fs3x hooked up to do bypass(tip), preset down(ring) , and preset up(tip and ring) default settings on space. All worked fine before I updated from v4 to v5. Now when I first turn space on all switches work except preset up keeps going to preset 1 nothing but, preset down to say, 80 no problem. hit preset up straight to preset 1. This can be fixed by holding down the right (tap) footswitch on space to change pedal mode, then hold right footswitch to change pedal mode back and all works correctly. If the power is shut off on space this procedure must be repeated for the footswitch to work correctly.Am I missing something or is this a fixable bug tia Baidie
June 15, 2014 at 5:31 pm #126144
We'll check it out and see if we can reproduce this. Thanks for the feedback.
June 16, 2014 at 6:35 pm #126152
Hi Baidie,
We can reproduce this issue here at Eventide. Good find! We'll work on getting it sorted out. Thanks.
June 19, 2014 at 3:23 pm #126165
Sounds like what I found a few weeks ago…
June 19, 2014 at 3:46 pm #136853
chrisjnyc:
http://forum.eventide.com/cs/forums/t/9305.aspx
Yeah, I think you're right. In any case we're working on a fix for this problem.
