strange noises with reverse on timefactor
Home Forums Products Stompboxes strange noises with reverse on timefactor
Viewing 4 reply threads
    • #106059
       I finally got around to making some reverse patches and im hearing a ringing sound from the TF. Im not getting the noise on any other patches only when I have the pedal set for reverse. Anyone else hear it?
    • #118269
      You can make some ring modulator sounds wih the TF. Is that this kind of noise you're talking to?
    • #118273
       No its a ringing noise that is happeinig with any reverse setting
    • #129365
       Post your settings and maybe a soundclip.
    • #129366
         If you are using the TF in an effects loop, try setting KILLDRY and see if that fixes it.
