Switch Stereo to Mono Configuration via H9 Control?
Home Forums Products Stompboxes Switch Stereo to Mono Configuration via H9 Control?
    • #114680
      jlane0710
        I have the H9 configured for stereo operation with two amps. Sometimes, I only turn on amp number one, however. No problem with many presets but with some, of course, part of the effect is missing (was sent to amp number two). I realize I could unplug the output number 2 jack from the H9 but on a pedal board that can sometimes require a can opener and needle nose pliers. Is there a way I am missing via the App to put the H9 in mono mode? If not, perhaps this could be added to a feature request list?
      • #148859
        bohan
          With two output jacks connected, when you change your H9's routing mode to Pre/Post, your H9 will work in Mono configuration (with all presets in PRE mode and amp 2 turned off).
        • #148861
          jlane0710
            A perfect answer to my question. Thanks?
