Home › Forums › Products › Stompboxes › tap tempo aux pedal
May 6, 2008 at 7:35 am #105627
hello since the new upgrade every time i switch on me TF it doesnt store my aux tap tempo pedal, i have to go everytime into the menu to learn it again.
anyone has the same issue?
thx kanifi
May 6, 2008 at 1:59 pm #117465
You probably have the aux pedal assigned improperly. Hold down the encoder knob and the tap switch. Turn the encoder until it says "aux sw". Then press the encoder again. Turn the encoder and make sure that tap is not assigned to more than one parameter. ESPECIALLY where you can assign FS1, FS2, or FS3 (these are the very last parameters under "aux sw"). You can assign your aux switches to FS1, FS2, and FS3. But you shouldn't have it assigned anywhere else. And, if you want your switches assigned somewhere besides FS1, FS2, or FS3, you shouldn't have anything assigned to FS1, FS2, or FS3. I had the same problem because I had the switches assigned in two places. It's easy to miss assigning FS1, FS2, and FS3 because they are at the very end.
May 6, 2008 at 2:20 pm #117466
thx a lot worked great now
kanifi
September 4, 2008 at 3:27 pm #117831
Thanks for the great advice – yes, my aux switches were double-assigned. After removing the second assignment the tap tempo setting is recalled after power down, but I'm not clear how to best assign the pedals to provide 1) bank selection
, 2) bypass/reverse/tap and 3) looper control for looper patches.Any recommendations? It seems I can have either bypass/reverse/tap or looper control, but not both – and I'd really love both 🙂
Thanks Eventide geniuses 🙂
