Temperance Lite is fantastic. Using it from Ableton Live, which has the notion of “scale”, with a root and mode, I’d love to be able to specify which scale degrees it should temper, in addition to which pitches. Besides better matching the way I think, the way TL would behave under automation would be even more wonderful. Mixing scale degrees and absolute pitches could be very interesting, too. Of course, degrees would be a bit trickier UI-wise, since depending on the mode there would be a different number of them.
Hopefully you’ll add this before I give in and hack it myself with Max for Live. 🙂
Thanks again!
Craig
