TF knobs don’t work…
Home Forums Products Stompboxes TF knobs don’t work…
    • #108839
      Hi everyone ,
      I read some post but didn't find my issue :
      everything is right except my knobs which don't respond at all !
      Seems my catchup function is engaged …. so I go to disengage it , but at last , it is NOT engaged…
      So I m lost ….
      Anyone knows what to do ?? ( to be noticed , the unit was not used for severals months )
      thanx
      Olivier
    • #123542
        You should try "Restoring Factory System Settings" as described in the UM. This will not erase any presets, but may change some settings.
        If this doesn't fix it, support@eventide.com
      • #123543
        perfect , I didn't try "clear setup" …. I thought I read the entire manual , but I must be tired …
        Thanx a lot !!!!!!
        olivier
