the art of noise
Home Forums Products Stompboxes the art of noise
    • #106075
       Hi
      i'm having a very tricky problem with my setup. I'm a lucky owner of a MF and a TF. I use them with my Rhodes and the setup is pretty straightforward :
      RHODES to MF to TF to AMP
      the problem is that i have a lot of hiss in the sound 🙁  I tried all the combinations of different  level i/o ( line guitar or amp level ) but unfortunately , still the same hiss and more with some combinations 🙁  Rhodes straight to the amp, no hiss.
      Cables were tested and they're ok. Power supply problem ? i/o level problem? Do i need a buffered-effect loop pedal ?
      Please help !
      thanks a lot
      Sorry for my sluggish english 🙂
    • #118306
         Not sure what the output level of a Rhodes is.
         Can you try it with a guitar and see if you have the same trouble ?
