Home › Forums › Products › Stompboxes › Thoughts on Mixing Link Mute
- This topic has 6 replies, 2 voices, and was last updated 2 years, 10 months ago by
Gebhard.Sammer.
February 15, 2023 at 5:58 am #169116
Is it true that when I set the Mix switch to Dry, only the FX Loop footswitch (off) mutes all outputs (DI/Line, Amp, Headphones)?
Thanks in advance
Geb
February 15, 2023 at 11:35 am #169131
What I wanted to write is ‚dry-only‘ (not dry, only ..,.)
February 16, 2023 at 4:04 am #169158
Info please (Hello EventideStaff):
Before I buy the ev missing link I want to know:
Can I mute all outputs with the footswitch by using
(a) Switch to FX only
or
(b) Switch to mix and set then mix-knob to zero?
Thank you for your advice!
February 16, 2023 at 11:06 am #169181
The footswitch only engages the FX loop. It does not mute all outputs. MixingLink does not have a “dry-only” setting.
February 16, 2023 at 12:35 pm #169185
thank you for the reply. However, a last question;: What happens if I use the EML with a microphone in (no inst in) and
scenario 1: footswitch „off“ and mix mode „fx only“
scenario 2: footswitch „off“ and mix mode „mix“ and mix knob counterwise to minimum?
Thank you!
February 16, 2023 at 3:55 pm #169199
You will hear the audio from the mic.
February 16, 2023 at 4:33 pm #169202
i got it 🙂 Thank you
