Home › Forums › Products › Stompboxes › Time factor going creasy – earth porbem ?
May 23, 2016 at 2:45 pm #143416This could be a bad pot, but is more likely to be a fault in the cable between the internal boards. If your unit is under warranty, you should send it in. If not, first have a technical friend take the top off and "wiggle" this cable to see if just needs plugging in better, or if the cable itself is faulty.
May 23, 2016 at 2:59 pm #113465Hi, I sometimes have this issue with my TimeFactor : – the expression pedal is still working – the tap tempo on the aux switch too – but the stompbox seems to sense many changes in all the pots on the stompbox itself. The problem happens even if I unplug the expression pedal, the aux switch and the inputs/outputs. The powersupply is a european VoodooLab pedal power 2 plus with a Voodoo Lab Current Doubler Adapter PPAP. I have the 5.2beta firmeware (I’ve update to it because I thought it could solve this), the problem is there since the begining (I’ve bought it in august 2011), but it happens not often. I don’t find a way to force the problem to find its origin… do you think it could come from a bad current ? best, rom
May 23, 2016 at 4:22 pm #143423Hi, thanks for the support ! My TimeFactor is nearly 5 years old, I don’t think the warranty will work… I’ll figure it out. The stompbox works very well 90% of the time, and when it’s going creasy I juste have to unplug the power for a few seconds to get it working. I’ll try to check the connections if the warranty is over. Thanks again.
June 10, 2016 at 8:16 am #143548After inspection (my TimeFactor is no longer under warranty), I did not see anything really wrong, I just inserted a sheet of paper modeled on the metal / plastic sheet separating the two electronic plates. This metal / plastic sheet is slightly conductive, and I feel that the loose connection came from there: by powering the disassembled pedal in voluntarily supporting this sheet on the top electronic plate (the one on which are soldered potentiometers) I could cause the behavior of the pedal in the video. Listed on the long term if the paper avoids these occasional madness of grain…
October 5, 2016 at 7:13 am #144561I had a problem very common on the TF, the screen would go crazy, I took unit apart and re seated the ribbon cable, this seem to fix that problem . After a few days i know have a problem where having edited my presets 1-10 the unit is responsive to changes tomsay the mix levels etc but then all the switches become frozen, turning tje unit on and off fixes this for a while but eventually the same thing happens. any ideas I would like to fix this myself. Nice Bedlington whippet by the way on eventide pic. -
October 5, 2016 at 3:05 pm #144566Hi Steve, Just a quick review of my little work on the TimeFactor : it works perfectly since I’ve put a simple sheet of paper between the two electronic plates. Best, rom
October 5, 2016 at 2:42 pm #144565My guess is that you still have a ribbon cable problem. But, have you tried re-initialization ?
October 5, 2016 at 3:18 pm #144567Thanks Rom , will try that and post results.
October 5, 2016 at 3:20 pm #144568Thanks for info, I have tried initialising , will try Roms paper trick .
