Time Factor not modulating
Home › Forums › Products › Stompboxes › Time Factor not modulating
Viewing 0 reply threads
    • #111876
      explodingPSYCH
        Hey guys,
        I just got a Time Factor and I'm loving it. My only concerns are as follows:
        In "Mod Delay" setting, with both delays set to "No Delay", Delay A modulates fine, while Delay B does not modulate at all. It seems to modulate normally after being switch to any delay time other than "No Delay".
        I also don't seem to be getting any kind of noticeable change when using depth/speed on the Reverse setting. Could someone explain to me what it's suppose to do and how I can go about noticing it.
        I've also read that other uses have found the same issue with Delay B not modulating when set to "No Delay" and that it's modulating is always less deep than Delay A.
