time factor stereo width when used as a mix efx
Home Forums Products Stompboxes time factor stereo width when used as a mix efx
    • #114063
      I have the time factor patched into my pro tools HD 96io, so I take a stereo pair from the TF outputs to inputs 7&8 and have an output in mono to the TF . I then create a stereo aux channel and call it bus 1&2 with the TF as a hardware insert . Then I create a bus from my guitar track to the aux . This is fine but I do not get the ping pong sound from side to side ,everything sounds great I am just after the width. Off the subject can anyone suggest the best way to print the guitar track with the effect included , I have tried various ways but either a big delay which the setting in hardware delay does nothing or if I the bus from the Aux track output to another stereo track nothing appears ? creating a bus send on the aux track and then setting the print track to the same bus works but feeds back before i get enough level ?
      Thanks for any help
      Steve
    • #145948
      Please ignore my last question ,during setting up,the time factor I somehow nudged my monitors controller to mono !
      I would still like to know how to print the track with efx .
