Home › Forums › Products › Stompboxes › Timefactor and MIDI tap tempo
July 16, 2011 at 4:47 am #107993
Hi, i'm a new timefactor user and i have very little experience with MIDI. I have a G-Lab GSC-2 guitar controller that sends midi CC and PC. When i set the tap tempo function, it sets half of the tempo in the timefactor unit. For example, if i tap 140 bpm on the G-Lab controller, the Timefactor is set at 70bpm… Is there a way to correct this?
This is what the G-Lab controller manual says about Tap Tempo:
tap tempo 3 – sending tap tempo (Ctrl CH #80, 0/127) to MIDI3 device
PS: Sorry for my bad english!
July 16, 2011 at 9:09 am #122406
Sorry, I don't know the G-Lab controller…but think I know what this is happening.
I had exactly the same problem with a Rocktron MIDIMATE and it is to do with the way the switches work on the controller. the easiest solution is to change the way the switch on the controller works, change it from a "Latching" style to a "Momentary" style and it should fix it…..the problem was you can not do this on the MIDIMATE, but you can on the other controllers I have tried (Ground Control Pro and Fractal MFC-101)
the reason it is happening is that the switch is set to "Latching" and this is like a stompbox. press once for "On" and press again for "Off"
the MIDI CC for "ON" is usually CC Value "127" and MIDI value for off is usually "0", so when you tap out a tempo on the switch the MIDI data sent is 127,0,127,0 etc. the Factor pedals only listen to values above 64 or 67 (can't remember the exact figure) so they would only process the 127 value and totally ignore the "0" for every other switch press which gives you 50% of the tempo you were expecting.
Assigning the switch to be momentary will fix this as each press will send the on CC value of "127" if you can not set the switch type to momentary see if you can assign the vallues for on/off to something other than "0" and "127" to something like "90" and "127" as this would then trigger the correct tap temp you would expect.
Hope that helps
July 18, 2011 at 12:14 am #122408
Thanks a lot, the "0" "127" thing was it. I figured out how to fix it, i don't know really how i didi it but now the preset is saved.
October 3, 2011 at 5:32 pm #133872
Hello diegocalvente!
I have exact same situation with exact same gear… I'd be glad to know how you fixed the problem? The G Lab manual is not so clear at the midi department…
Cheers
October 11, 2011 at 8:58 pm #122735
Hi.
G-Labs tempo function toggles CC-message value from 0 to 127 ( first tap 0, second tap 127 etc…)
Eventide regonizes only CC-value 127 as a tap tempo.
My solution was to unable G-Labs tempo function and programming one of the switches as midi modifier, sending CC-value 127 every time it's pressed.
October 12, 2011 at 7:19 am #122739
Hi FallenAudio,
Thank you for the advice, now it works!
/Miska
