Timefactor Aux-Switch for Prests
Home Forums Products Stompboxes Timefactor Aux-Switch for Prests
    • #108125
      sanativ
        Hi there!
        I have used the axefx in the last time, but now i´back with my good old Timefactor V3! Now, I´d like to put the TF into the rack and use my 3-button aux-switch for direct axess to three different presets. Does anybody knows how this works?
        This would be great for using the Aux-switch as a minimized midiboard!
        Frank
      • #122718
        achaput
          Inside the AUX Switch Menu are choices for FS1, FS2, and FS3. These will cause the Aux switch to operate just like the onboard footswitches but in the opposite mode that the pedal is in. In other words, If the pedal is in PLAY mode then the Aux switch will operate as if the pedal were in BANK mode, when set to FS1, FS2, and FS3.
          In this way you can select presets via the Aux switch.
