Home › Forums › Products › Stompboxes › Timefactor & Aux switch question
October 8, 2008 at 5:12 pm #105868
I'm using a Digitech FS300 footswitch with theTimefactor. It has three switches.
Right now the middle switch controlls the Repeat Hold function. I'd like to set the middle switch to do nothing.
How do I do that?
Thanks.
October 11, 2008 at 4:49 pm #117931
So, I guess it can't be done……….??????
Anybody???
October 13, 2008 at 3:07 pm #117935
Hi Straticus,
If you would like to de-assign a swith on your aux switch you will need to access the System Mode>Aux SW menu within the TimeFactor OS and configure the corresponding switchs to a null mode or "- – -" within the menu selection. As a system default, TIP is assigned to BYP, T+R is assigned to TAP and RNG is assigned to repeat. Whatever footswitch that you presently do not want assigned just configure the parameter assignment to "- – -". So with regard to your situation, you will want to change the assignment so that it resembles this "RPT > – – -" There is not save function so once you have made the desired assignment you merely exit System Mode.
For more information on aux switch assignment, reference page 32 in the user manual.
Best of luck!
October 13, 2008 at 4:11 pm #129103
Thank you very much!
BTW, I'b been gigging with the Timefactor lately and it sounds amazing.
October 13, 2008 at 4:16 pm #129104
You're welcome!
Enjoy!
