Timefactor : Delay even when the unit is bypassed
Home › Forums › Products › Stompboxes › Timefactor : Delay even when the unit is bypassed
    • #113545
      Hello all,
      I have a Timefactor and I just updated the firmware to the lastest version and since I did that, when I’m on a preset and I push on the active button to bypass the effect, It doesn’t disengage the effect, so the effect is still there even on bypass.
      Does somebody has a clue on that problem?
      Thanks
      Fred
    • #143753
      gkellum
        You might want to try reinitializing its system settings to make sure that there's not some unexpected problem with its settings.  To do so, turn it off and then turn it on again with the right footswitch and the algorithm selection knob pressed.
      • #143754
        Problem solved!
        Thanks Eventide staff, you are magic!!
