Timefactor expression pedal input not working
Home Forums Products Stompboxes Timefactor expression pedal input not working
    • #113036
      knifey
        Hi, I have a Timefactor and had the expression pedal work before I recently updated the firmware to the most recent one (5.2), and now neither my Roland EV-5 (brand new) nor the M-Audio EXP is working with it. I’ve tried everything – turned the knobs on the pedals, turned PDLCAL on and off, PDLOCK on and off. The pedals themselves work for sure. Any ideas?
      • #141589
        gkellum
          Well, if you haven't done so already, you should try resetting the TimeFactor's system settings by turning it off and then turning it on again with the right footswitch and the algorithm selector knob pressed.  This will wipe out any setting changes you made, but it won't affect your presets.  For whatever reason a lot of people have run into problems with this v5.2 upgrade that can be cleared up just by doing that.
        • #141590
          knifey
            YES!! that worked! Thank you so much for that.
