Firmware 5.2.0[6]
Hi again,
When switching delay types via the encoder, while repeat is on, it sounds like repeat is turned off, however the associated LED stays on. When pressing the repeat switch again after switching delay types, even though the repeat light was already on, it stays on and the display reads “RPT ON”.
I’m thinking this should be fixed so that either repeat stays on, or the light goes off, when switching delay types with repeat on.
PS there’s a neat trick you can do by turning on spillover, enable repeat, switch delay types, and letting it run at high feedback for a few cycles with repeat off, before enabling repeat again and switching back to the original delay type – to process the delay buffer using the effect of another delay type. IMO it would be ideal if repeat could simply stay on while going through different delays with spillover on. (In fact it probably wouldn’t hurt to keep the repeating buffer even when spillover is off, so that the repeat function could be used, always, as a sort of on-demand spillover.)
