TimeFactor Tempo…?
Home › Forums › Products › Stompboxes › TimeFactor Tempo…?
    • #114243
      Simple question – the TimeFactor Manual says:
      “If ON, MIDI Clock is used as the Tempo source, instead of Tap. “
      So is there no way to have MIDI tempo incoming and have an auxiliary switch hooked up to tap tempo in as well… at the same time?  Is it either one or the other?
    • #146710
      gkellum
        Yes, that's correct.  It's either one or the other.
