I have a Time Factor with Version 2.4.2[1] software and I found a
trouble when I'm using a looper and my pedal is set in Relay Bypass
Mode:
– The first time that I use the loopers everything works well but when
I empty the loop I can't record anything. The time number on display is running
and apparently the sound is recorded but when I press play no sound
appears.
– When I'm using DSP or DSP+FX Bypass Mode everything works well even
when I empty the loop.
I don't know if this problem is related to my pedal or the software.
My Time Factor is new (just 2 mouths) and I always use carefully.
If someone can help me, I'll be thankful.
Show More...Show Less...
