Two expression pedals
Home Forums Products Stompboxes Two expression pedals
    • #113560
      Hi!
      I wondered if it would be possible in next updates to be able to connect two expression pedals at the same time on the H9
      The goal for me is to be able to use the pitchflex algorithm as a whammy pedal with the first expression pedal and to use volume swells with the second expression pedal on the same patch. Is is possible technically speaking? Is this possible in a future update?
      Cheers Guys!
    • #143809
        It is technically possible, but not the way the software works.
        Given the trouble people seem to have in using a single expression pedal, two might be too much.
        A MIDI pedal might be the answer. (See "MIDI Solutions", etc).
