Hi all
Is it possible to use UltraChannel as an aux-send? I would like to use the delay-module, but it seems to be impossible to use it as an aux-send.
It is not feasible to use the delay-module when inserting UltraChannel on the track itself, since it would combine with other aux-sends later on in the mixing process, such as reverb, parallel compression, etc. The same goes for the micro pitch shift-module.
I hope the developers make it possible to mute the direct signal in plugin settings, underneath the scaling option.
You must be
logged in to view attached files.
