update failing..
Home Forums Products Stompboxes update failing..
Viewing 3 reply threads
    • #105556
      Timefactor recognised by pc(windows xp) and i could view the list of update file in eventide update utility. after typing the username and password, and accept the terms and readme content, the error appears.
      Assertion failed!
      Program:….ntide update utility eventideupdateutility.exe
      File: . httpthread.cpp
      line: 459
      Expression: !fileName.isEmpty()
      help please?
    • #117340
      manual update did the trick, works perfect!
    • #117346
       apologies I posted on another thread with the same problem. How did you do the manual update??
      Thanks,
      enda
    • #128463
      Big thanks to Alan who helped me out on this question, here is the reply i got from him.
      Please try downloading the TimeFactor update file from your browser using this link:
      http://update.eventide.com/update/bam/209032_V2.0.2b4.bam
      Attach TimeFactor to your computer via USB. Power up TimeFactor while holding the middle footswitch. Launch the Eventide Update Utility.
      Then, select the 209032_V2.0.2b4 downloaded file from the Eventide Update Utility using the ?Update from File? selection under the File Menu.
      Let me know if you can update this way.
      Alan Chaput
      Eventide
