updated but still no SpaceTime
Home Forums Products Stompboxes updated but still no SpaceTime
Viewing 3 reply threads
    • #142366
      Boynigel
        OP here.  i got it sorted out.  everything is working now, thanks
      • #113207
        Boynigel
          i did as the website said and updated to 5.3.0 but SpaceTime doesn’t show up for my H9 Max after completing the update.  i checked all my algorithms and it’s not there.  it’s not even in the store section, not that i’d need to buy it being a maxed out H9.  what gives?
        • #142409
          What did you figure out?  Not seeing mine either after update
          • #142410
            gkellum
              You'll need to update both H9 Control and the software on your H9.  If you have a Max in most cases after you do this, you should be able to start using SpaceTime immediately after doing this.  If not, using the Restore Purchases function under Settings should do the trick.
          • #142411
            Solved.  I needed to update the H9 app on my Ipad.
