Usb-serial
Home › Forums › Products › Vsig and Preset Development › Usb-serial
Viewing 4 reply threads
    • #107969
      If I buy a better (v.2?) usb-serial, will I be able to hotswap the H8000fw to my notebook with Vsig?
      Thanks
    • #122349
        Sorry, don't understand
      • #122350
        Hotswap, meaning plug/unplug usb without turning H8000fw off/on, working with Vsig. Is it possible?
      • #133554
          If you are using a USB to serial to connect to the H8000, it won't care if you disconnect and reconnect the USB. But, Vsig will probably be confused – this is not good practice.
          If you set Vsig up for "MIDI/auto disconnect" it will probably be OK, as long as you don't disconnect the USB while it is using it (sending or receiving)..
        • #133556
          Thanks. Then it is my "ancient" usb adapter (usb v.1.1) that is not allowing to hotswap and I will need to update.
