Use Expression Pedal to sweep BPM in order to select a tempo?
Home Forums Products Stompboxes Use Expression Pedal to sweep BPM in order to select a tempo?
    • #113178
      JW1970
        I’m far from knowledgeable about midi and using expression pedals.  But I was wondering, can an expression pedal be assigned on an H9 or ‘Factor so that the pedal sweeps through tempo settings rather than having to tap a tempo?  I’m looking for a quick way to just jump to specific tempos on the fly as the need arises — not preplanned so I don’t want to use a midi controller w/presets and don’t want to bend to twiddle a knob.  And the idea is that I’d keep the delay settings to note values rather than milliseconds.
        Is this even possible?  I don’t own an expression pedal so can’t investigate by trial and error.
      • #142239
          Sorry – can't do this at the moment. I see a possible problem in that you tend to want a tempo to be fairly precise, which might be hard to do with a pedal.
        • #142240
          JW1970
            Okay.  Thanks for the reality check and quick response.
