Using Midi to change bank and patch with a Mod & a Timefactor pedal
Home Forums Products Stompboxes Using Midi to change bank and patch with a Mod & a Timefactor pedal
    • #111513
      Hi all,
      New to the forum and have just purchased a mod & timefactor stompboxes for my board.
      I've got these two units connected via midi and I basically want to synchronise the pedals i.e;
      1. when I select a bank on the modfactor the same bank is selected on the timefactor
      2. When I select a patch using the one of the footswitches the corresponding patch is select i.e. when 1:2 is selected on the modfactor the same is selected on the timefactor
      Is this possible to do and could anyone point me in the right direction as I'm new to the use of MIDI.
      Thanks in advance,
      Simon
    • #125660
      gkellum
        Check out the tutorial video about this (video # 7):
        http://www.eventide.com/Home/Eventide/AudioDivision/Products/StompBoxes/StompboxTutorials.aspx
        Also, here's a forum post where someone ran into some trouble doing this with some useful tips:
        http://forum.eventide.com/cs/forums/p/6827/30063.aspx#30063
      • #125667
        Thanks very much – works a treat!
        Simon
