Using two amps with Time Factor
Home Forums Products Stompboxes Using two amps with Time Factor
    • #109092
      I am using two amps with the pedal to maximize the stereo effect.  Ois a Fender Deluxe and the other is a solid state Crate amp.  The Deluxe works fine but the other amp does not seem to work well.  The volume of the 2nd amp is always lower than it is when I plug directly into it.  Is there some reason that the volume feed into the two amps is different?  Can it be adjusted?
    • #123813
      achaput
        Have you tried adjusting the Dly mix knob? This controls the balance between the two outputs.
      • #123833
        Maybe check the switch on the back of the TF to make sure it's set to amp level for the output, rather than line level.
        If that's not the problem, then I'm wondering if you mean the whole level–including the dry–is lower out of the Crate than the Fender? If it's just the wet that's lower, then I'm guessing it's because the tube amp is compressing more than the crate? I use my TF through a Fender Hot Rod Deluxe set to sound clean and through a Marshall Plexi clone set to light overdrive. The delays compress (upwards) a lot more in the overdriven amp, so they sound louder.
