What is the best expression pedal to use with the Pitch Factor
Home Forums Products Stompboxes What is the best expression pedal to use with the Pitch Factor
Viewing 4 reply threads
    • #106321
      What is the best brand and model of expression pedal to use with the Pitch Factor
      Terry
    • #118810
      According to the postings I've seen the Ernie Ball Jr 25K pedal is the way to go.
    • #118875
      Har
        I've been using the cheap-o M-Audio EX.P expression pedal here with mine and it works just fine. it ain't the most sturdy thing out there to be sure – you get what you pay for in terms if build quality – but for my studio needs it's been working out very nicely for me. Smile
        Were I planning on using it for a rougher live/road environment I'd probably opt for something sturdier, though.
      • #118926
        As far as I can see Ernie Ball make two kinds of Ernie Ball Jr 25K pedals, active and passive.
        Which one do I need for the pitchfactor and timefactor?
        Thanks,
        Stvy
      • #130057
        Actually they make an "active" 25k ohm version (model 6181) and a "passive" 250k ohm version (model 6180) of the Volume Pedal Jr. You want the 25k ohm version which is for active instruments and is model number 6181.
