with bluetooth connectivity, can I have multiple H9’s ?????
Home Forums Products Stompboxes with bluetooth connectivity, can I have multiple H9’s ?????
    • #111605
      does each get its own "channel"?   how do I select which box I want to interact with ?
    • #125885
      badmelonfarmer
        You get a list of the multiple H9's in the left hand side.
        you also get the names at the top of the screen with a spinning arrow showing the one that is active in H9 control…. You can click on the other name(s) to switch between H9's
        by default the names are the same as the standard Bluetooth name eg H9-12345 where 12345 is the serial number of the H9…. You can rename them to something more sensible to you. I labeled mine H9-1, H9-2, H9-3 and put labels on them so I know what is what.
