Home › Forums › Products › Vsig and Preset Development › when the specifier display does not work.. › Reply To: when the specifier display does not work..
January 21, 2008 at 2:09 pm
#116791
Hi Harrie
I assume you refer to Vsig V2.4.9.1.
I have no problems at all like the ones you describe; working w/2 monitors here too.
Maybe the module specifier opens somewhere in your displays setup, as a very small window that needs resizing (and maybe relocating on a desired monitor)?
In any case close Vsig and erase the VSIGFILE.ini file in the Windows directory. This should fix everything.
Let me know.
I
