Home › Forums › Products › Stompboxes › Time Factor Back-Up Dump Help › Reply To: Time Factor Back-Up Dump Help
March 2, 2008 at 10:39 pm
#117066
Yes. The procedure of dumping is as you say. MidiOX is a bit complex application and I had problems in using it especially for what concerns the buffer settings (it's not said in the Timefactor user's guide hot to configure it).
Another very strange thing is that my pc (WinXP with Service Pack 2) doesn't recognize the pedal as an usb device. Has someone of you the same problem?
