Home Forums Products Stompboxes Post your TimeFactor V2.0 Beta bugs here Reply To: Post your TimeFactor V2.0 Beta bugs here
#117349
when using the "BYPASS + DSP" setting..
if you have a stereo preset with long delay trails, when bypassed the trails will continue to ring on as they should — BUT the two outputs are apparently summed when the unit is bypassed.  so a stereo delay trail will sound "mono" once you bypass the preset.  not sure why the two outputs don't remain independant in bypass mode.
in reverse mode.. the delayed signal is noticeably louder than the bypassed signal when mix is set to 100%.
the looper "hiccup", and the fact that there still doesn't seem to be a way to set both the input and looped signals to full/unity volume. when set to 50/50 there is a noticeable volume drop when the looper is engaged.
