Home › Forums › Products › Stompboxes › expression pedal with tap tempo › Reply To: expression pedal with tap tempo
April 14, 2008 at 2:07 am
#117360
thanks for the response.
in this instance do you have to use an auxiliary switch for tap tempo, or can you just use the onboard tap tempo switch – either way if fine, just curious.
