Home › Forums › Products › Vsig and Preset Development › Harmonic Leaping (moved from Harmonizers section) › Reply To: Harmonic Leaping (moved from Harmonizers section)
April 15, 2008 at 12:23 am
#117372
I spoke a little too fast. I have a debilitating output level problem. I use a stereo amp, and the preset above is stereo, although the algorithm is 100% symmetrical. In any case, the left channel is getting almost no volume, whereas the right channel is perfectly fine at full volume.
I checked the input levels and see no issues, all at 0db.
Any ideas? Can you try my code on your machine?
Is it possible that the expression pedal that I use somehow also controls the input or output signals against my will?
