Home › Forums › Products › Stompboxes › Modfactor Update/Volume Issue › Reply To: Modfactor Update/Volume Issue
#117404
 As far as the Leslie, you can turn it down a bit by editing the patch… change the ratio of the horn to the bass speaker, so that the lows end is lowered, I think it's the "shape" knob.  This will thin it out, and then you can turn the tone with the Xknob to keep the horn tone from being too bright.
