Reply To: Switching menu pages via MIDI?
Home Forums Products Rackmount Switching menu pages via MIDI? Reply To: Switching menu pages via MIDI?
#117407
IDeangelis
You may try Orville SysEx code if your controller allows programming of hex strings.
BYTE#    Hex Value      Description
1             0F0               SYSEX start
2             1C                 Eventide I.D.
3             70                 DSP4000 Product I.D.
4             1~63             Device I.D.
13            F7                SYSEX stop
BYTES 5 thru 12 must be filled with datas in the bottom tables
sysex button presses are ?nibbled?, this means that F = 0F
Example FFFFFDFF would be 0F 0F 0F 0F 0F 0D 0F 0F (8BYTES)
Here is a full example of the sys ex string for <bypass>:
F0 1C 70 01 01 0F 0F 0F 0F 0F 0D 0F 0F F7
 B U T T O N S                  C O D E                        N I B B L E C O D E
<BYPASS>                       FFFFFDFF                   0F 0F 0F 0F 0F 0D 0F 0F
<SOFT 1>                         FBFFFFFF                   0F 0B 0F 0F 0F 0F 0F 0F
<SOFT 2>                         FFFBFFFF                   0F 0F 0F 0B 0F 0F 0F 0F
<SOFT 3>                         FFFFFBFF                   0F 0F 0F 0F 0F 0B 0F 0F
<SOFT 4>                         FFFFFFFB                   0F 0F 0F 0F 0F 0F 0F 0B
<A/B>                               FDFFFDFF                   0F 0D 0F 0F 0F 0D 0F 0F
<PROGRAM>                    F7FFFFFF                   0F 07 0F 0F 0F 0F 0F 0F
<PROGRAM-HOLD>          F7FFFFFE                   0F 07 0F 0F 0F 0F 0F 0E
<PARAMETER>                FFF7FFFF                    0F 0F 0F 07 0F 0F 0F 0F
<PARAMETER-HOLD>       FFF7FFFE                   0F 0F 0F 07 0F 0F 0F 0E
<SELECT>                        FFFFFEFF                   0F 0F 0F 0F 0F 0E 0F 0F
<SELECT-HOLD>              FFFFFEFE                   0F 0F 0F 0F 0F 0E 0F 0E
<CURSOR-LEFT>              FFFEFFFF                   0F 0F 0F 0E 0F 0F 0F 0F
<CURSOR-UP>                 FEFFFDFF                   0F 0E 0F 0F 0F 0D 0F 0F
<CURSOR-DOWN>           FFFEFDFF                   0F 0F 0F 0E 0F 0D 0F 0F
<CURSOR-RIGHT>            FEFFFFFF                   0F 0E 0F 0F 0F 0F 0F 0F
<LEVELS>                        FFFFFFFD                   0F 0F 0F 0F 0F 0F 0F 0D
<SETUP>                          FFFFF7FF                   0F 0F 0F 0F 0F 07 0F 0F
K E Y P A D S                    C O D E                     N I B B L E C O D E
<1>                                    7FFFFFFF                 07 0F 0F 0F 0F 0F 0F 0F
<2>                                    FF7FFFFF                 0F 0F 07 0F 0F 0F 0F 0F
<3>                                    FFFF7FFF                 0F 0F 0F 0F 07 0F 0F 0F
<4>                                    BFFFFFFF                 0B 0F 0F 0F 0F 0F 0F 0F
<5>                                    FFBFFFFF                 0F 0F 0B 0F 0F 0F 0F 0F
<6>                                    FFFFBFFF                 0F 0F 0F 0F 0B 0F 0F 0F
<7>                                    DFFFFFFF                 0D 0F 0F 0F 0F 0F 0F 0F
<8>                                    FFDFFFFF                 0F 0F 0D 0F 0F 0F 0F 0F
<9>                                    FFFFDFFF                 0F 0F 0F 0F 0D 0F 0F 0F
<0>                                    FFEFFFFF                 0F 0F 0E 0F 0F 0F 0F 0F
< . > (dot)                           EFFFFFFF                 0E 0F 0F 0F 0F 0F 0F 0F
< – > (minus)                       FFFFEFFF                 0F 0F 0F 0F 0E 0F 0F 0F
<UP>                                 FFFFFF7F                  0F 0F 0F 0F 0F 0F 07 0F
<DOWN>                            FFFFFFBF                0F 0F 0F 0F 0F 0F 0B 0F
<CXL>                                FFFFFFDF                 0F 0F 0F 0F 0F 0F 0D 0F
<ENT>                                FFFFFFEF                0F 0F 0F 0F 0F 0F 0E 0F
examples :
<PROGRAM> = F0 1C 70 01 01 0F 07 0F 0F 0F 0F 0F 0F F7
<SELECT> = F0 1C 70 01 01 0F 0F 0F 0F 0F 0E 0F 0F F7
I haven't tested these strings on the H-series but I'm confident they will work. Please give it a try.
best
