Home Forums Products Stompboxes Mix control vs. intensity Reply To: Mix control vs. intensity
#117434
DGillespie
    Hi GtrWiz,
    The reason we went with Intensity over Mix is that not all of these effects lend themselves to a mix control. For instance Mix would be redundant on Tremolo where it would do the same thing as Depth. It would also screw up the Rotary and do unexpected things with the Wah. Which effects do you wish you had a mix control on?
    Dan
