Home › Forums › Products › Stompboxes › Mix control vs. intensity › Reply To: Mix control vs. intensity
#117437
Thanks for the reply Dan,
Not being a designer type, I really have no idea how this affects things, but basically I  like to mix in the original signal to my effects. Keeps it more organic sounding. I can see how it might not be useful to things like tremolo, but I've had great results with other effects like Phasers, and choruses set for leslie type effects. Why would it screw up the rotary?
I'm starting to wonder if I can get similar results using the KillDry with it in my fx loop… Not quite sure how all that works, I've always been one to run effects to the front end of a clean amp.
 Chris
PS, did y'all know what you were getting yourselves into when you decided to get into stompboxes? 🙂
