Home › Forums › Products › Stompboxes › Modfactor issue – FX Loop phasing issue with Trem/Pan › Reply To: Modfactor issue – FX Loop phasing issue with Trem/Pan
May 14, 2008 at 3:41 pm
#117494
Does this still happen if you set KILLDRY to on? If the dry signal is returning from the effect loop that may also cause this problem. Does the problem go away if you set your effects loop to series?
Can you tell us more about the self-noise when in front of the amp?
