Home › Forums › Products › Rackmount › Front of the amp/Loop Simultaneously? › Reply To: Front of the amp/Loop Simultaneously?
#117531
 Eclipse is not designed to handle different signal levels/impedances at the same time.
Don't use it as described.
Every product has something special. Time Factor looper is not available on Eclipse. Other effects may be slightly different.
best
I
